  • SN95 V6 Mustang Tech
Please Help!
  • Thread starter Thread starter uscgirl67
  • Start date Start date Aug 30, 2006
U
uscgirl67
  • Aug 30, 2006
I own a 2000 Ford Mustang Convertable, automatic transmission. For awhile now, I have had this horrible sound coming from under my hood when I accelerate and pretty much whenever my foot is on the gas pedal. It sounds like I have a diesel engine. I've taken it to get fixed a few times, and they always say nothing is wrong, but the sound is getting progressively worse. I have tried adding higher octane gas and other additives and nothing helps. Does anyone know what could be causing this or ways to remedy it? Thanks for your help.
MustangLX-5.0
856
Lehigh Acres Fla.
Sep 9, 2006
  • Sep 9, 2006
Ok,so how many miles does it have? Have you noticed any smoke or unusual smells coming from the engine? And how is the oil level? If you havn't checked it lately then now may be a good time.Check for any fresh fluid leaks from under your usual parking area.And one final question/s...Does it feel like you've lost any power,seeming slower than usual? And has your Check Engine light came on at all?
I would also try taking your ride to another mechanic and get a second opinion.Also,I forgot to ask,Does the noise get louder if you step harder on the gas?
TMX
Houston
Sep 11, 2006
  • Sep 11, 2006
If it's anything like my 2000, it is kind of missing, but not bad enough to set off a code. Hesitation and kind of a ticking/tapping/dieseling sound that gets worse as the engine gets warmer, but I have new plugs, new wires, new battery, new fuel filter, new fuel pump, have ran seafoam twice, changed the oil, ran oil cleaner, and even tried 89 octane. I do know on the 99-00 and some 01's, the valve covers lacked a sufficient baffle that allowed quantities of oil vapour to pass through the PCV and into the intake. Going to be intalling an inline fuel filter into my PCV line to stop the oil and test all my injectors to make sure they are openning and closing correctly.
MustangLX-5.0
856
Lehigh Acres Fla.
Sep 11, 2006
  • Sep 11, 2006
Does it by any chance sound like it's coming from just below the center of the intake manifold? Let me know.
I can record some audio from my 96 v6 from within said location to see if that is what you are hearing.You may also be hearing excessive rocker arm noise which would be coming from just under the valve covers....but then again I can't say unless I actually heard it for myself.
Zero_chance
1,244
Maricopa, AZ
Sep 14, 2006
  • Sep 14, 2006
Exactly. Its hard to diagnose a noise without hearing it. Have you tried taking a mechanic from the shop you go to for a ride to hear the nosie for themselves? Because itd be pretty hard for them to say nothings wrong if youre pinpointing the noise for them.
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
K
2000 3.8 v6
  • Kinglife2121
  • Nov 2, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 2, 2025
Kinglife2121
K
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
U
8 Years of Vibration leading to engine knock?
  • UpgradeXP
  • Apr 14, 2025
SN95 V6 Mustang Tech Apr 14, 2025
