i have a 87 vert with a bad 5.0, i have an 84 5.0 from a mustang i bought. gt40p heads can get anything that a friends salvage yard has in stock but i need to know what to ask for, numbers or application will be only a toy to see if i can build a ford that will run as fast as his chev. can get a stroker kit
Unuesd Sub-frame connectors witout seat braces $50
70mm TB and spacer with IAC and EGR valve, unsure of brand $80
Used Motorsports 50oz balancer part number M6316 A50 $125
Used set of Ford OEM 373 gears with bearing still on pinion $40
Used motorsports shorty unequal headers $75
4 banger front springs $40
New CAT sfi approved 157 tooth 28oz manual flywheel, steel $125
NEW 347 Rotating assm
MAHLE race pistons, flattop and oil ring does not intersect ring land
HAWKS RACING SERIES 8000 NODULAR IRON CRANKSHAFT WITH STD/STD SB FORD JOURNAL SIZES
CNC PROFILE LIGHTWEIGHT FORGED I-BEAM RACE RODS W/ARP BOLTS
PIN FIT PISTONS PISTON PINS AND RACE PROVEN LOCKS
(NOTE: PISTON PIN BORE DOES NOT INTERSECT THE OIL RING GROVE... TO ELIMINATE OIL USAGE PROBLEMS COMMON WITH JE/SRP PISTON EAGLE KITS AND MOST OTHERS!!
NEW KING RACE STD/STD ROD AND MAIN BEARING SET
PREMIUM MAHLE MOLY RING SET
$750
can i use it what cam ect anything will help i am a chrysler tech trying to change thanks terry also if you have anything to sale i need please also let me know
$750
