please help
cwdavis_02
i have a 92 lx 5.0. car was originally a 4cy
now has a full 1991 v8 wiring harness from front to back. has a v8 5.0 with a 4cy 5sp tranny.
problem is the car will start run for a few seconds then shut right back off.
I dont what it could be any help with this matter would be great.
thanks guys
if i turn the key back to the off position and then try it restart it it will start run for a few seconds then cut off. its almost like the fuel pump is cutting off or i lose fuel pressure.
Do you have a fuel pressure gauge that can be watched while this happens?
Are you sure the IAC is functioning properly?
no i dont have a gauge. but i might be able to locate one. no im not sure about the iac. but i dont know what that or where that is? this is my first efi car. what are the symptoms of a bad iac?
My initial assumption is that the fuel pump is priming which gives you the fuel that you need then shuts off when the car is actuallly on.
I read that it has a full wiring harness from a 91 but just to clarify this is from nose to rear?? including the engine harness and under dash harness?
A fuel pressure gauge can be obtained on loan from AutoZone, Advanced Auto Parts or one of the other major auto parts chain stores.
Here is the fuel pressure test point. This one has a line on it for the fuel pressure gauge. Yours will probably have a schrader valve on it.
The IAC or IAB is the idle air control for the idle speed. If it does not work, the engine may stall or die.
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
ok it appears that i had a vacuum leak. now my issue is i went to start it today and it just turned over. it would try to start every now and then. then it would start and stay running. if it revved the motor it would die down and cut off. then restart eventually.
Diagrams courtesy of Tmoss & Stang&2birds
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 86-95 5.0 Mustang wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 88-91 5.0 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 91-93 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
Vacuum Diagram 87-93 Mustangs
The diagram says 88 Mustang, but except for the vacuum line connected to the MAP/Baro sensor, it is the same for all 5.0 Mustangs from 87-93. The 89-93 Mustangs vent the MAP/Baro sensor to open air.
http://www.veryuseful.com/mustang/tech/engine/images/88Stang5.0Vacuum.gif
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
ok vacuum leaks are fixed but im still having the starting issue. when the car runs for a few mins it will restart and run.
Also i discovered another big problem today. none of my dash lights work. when i turn on the headlights all the lights in the front of the car come on. when i hit the left turn signal the idicator light flashes. when i hit the right on the instrument cluster lights on the right hand side flash. when i adjust the dimmer switch the fuel gauge moves. I pulled a harness from a 91 v8 car and put it in my 92 4cyl car. i used the entire harness from the front to the back from the 91. Can anyone help me?
i really appreciate all of the great help ive received from this site.
Do the checklist when it won't start...
No Crank checklist for 5.0 Mustangs
Revised 05-Oct-2010 to update Fluke references.
No crank. slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of both no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a know problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstuck and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachment.php
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachment.php
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
attachment.php
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachment.php
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
attachment.php
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
I check all that stuff. the problem is more so when its cold. it will jus spin over. i found out today that if i spray some starter fluid in it it will fire and run for a few. it seems like once the motor gets warm it will stay running. but i took it up the road today then when i got home it would turn over and start. then cut off. then i could try again and it would start then cut off again. it repeated this over and over. what should i check next?
