please help
  • Thread starter Thread starter tims91pony
  • Start date Start date Apr 23, 2011
T
tims91pony
  • Apr 23, 2011
I have 91 5.0 mustang that i just put a e303 cam in stock heads gt 40 intake no cats h pipe 70 mm throttle body my problem is that it sounds like a bunch of sewing machines its not hitting valve covers the rockers are all torqued right ck 5 or 6 times are my lifters not pumped up or failing pushrod length wrong not sure where to look nextvalvetrian is all stock except cam hope i have given enough info for help if not please ask and i will provide thank you
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Apr 24, 2011
  • Apr 24, 2011
Check your header/exhaust manifold bolts and tighten them if they are loose and check the smog crossover tube behind the heads and make sure the two bolts are tight. Then see if you still have the noise.. and if you are still hearing it .. you may have a rocker/ pushrod problem.
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Apr 24, 2011
  • Apr 24, 2011
With both valves closed on a particular cylinder, how much play do you have with the rockers and pushrods? Check each cylinder. Some like them to be looser than others, but I like to just be able to spin the pushrods by hand with the valves closed. Others may chime in with more detailed responses.
T
tims91pony
  • Apr 24, 2011
rocker noise
there is alot of play i can actually move the rockers back and forth and slightly up and down the noise is for sure coming from the valve covers it does seem to be on the exhaust side?
2000xp8
SN Certified Technician
Aug 8, 2003
8,071
1,655
194
NJ
Apr 24, 2011
  • Apr 24, 2011
It's probably the rockers. What type are you using?
An e cam with stock heads and stock valves springs isn't that great of an idea, yes you can do it, but the springs aren't going to last long.
T
tims91pony
  • Apr 24, 2011
all stock, except cam(lifters,rockers,springs and pushrods) would 1.6 roller rockers and springs solve the problem? thanks for your help
RangerJoe
2,560
1,146
184
Georgia
Apr 24, 2011
  • Apr 24, 2011
Sounds like you need longer pushrods. You should be able to turn the bolts on the rockers by hand until they stop (this is with both valves closed), then torque the bolts 18-20lbs. I believe you should turn 1/4 turn or so before it hits torque. Did you shim the rockers by any chance? If you did, try taking the shims out. Many things can affect pushrod length, changin a cam is one of them.
T
tims91pony
  • Apr 25, 2011
I did not shim the rockers i would agree that i need longer pushrods i was told that i would not need to change but that seem unlikley at this piont any suggestions on length or will i have to get a measurment between rocker and valve stem also it seems that my play is all on the exaust side of things at this point any other advice would be greatly appeciated thank you so far you have been very helpful
2000xp8
Aug 8, 2003
8,071
1,655
194
NJ
Apr 25, 2011
  • Apr 25, 2011
Goto summit racing and get a pushrod length checking tool.
Might as well get some ford racing 1.6 rockers while you are at it.
Changing the cam while leaving the stock heads generally isn't a good idea.
It can create headaches and provides very little power gain.
Consider if you have a few more bucks available buying a set of gt40 irons off a cobra based engine or an early explorer 5.0.
Then upgrade the springs and use the 1.6 rockers. At least this way you will get something for your money.
T
tims91pony
#10
  • Apr 26, 2011
  • #10
I have the heads from the explorer that the intake came from i could use gt 40p heads i just cant seem to wrap my head around the idea that the length of the pushrods would change from just a cam swap but anything seems possible at this pointthanks for you help
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
