I've been told that winter-weight turn-signal fluid, but only for the right turn side will help get those seals off....
(now, what was I ignoring?)
Yeah, winter-weight would probably help.... just remember to wipe it off your o-pipe before you use the air chisel.chepsk8 said:I've been told that winter-weight turn-signal fluid, but only for the right turn side will help get those seals off....
You mean to tell me all that fuzz between my toes is actually from my SOCKS!mustangdave said:Now, if we could just invent a sock that doesn't leave fuzz between your toes when you take it off......
But I hear that that hair removal called Nair the ladies use will get rid of that toe fuzz for you.
65stanger said:You mean that wasn't Nair I had been using?![]()
Dammitdammitdammitdammitdammit! How many times have you got to be told that stuff goes on the shelf in the workshop, NOT the bathroom!StangDreamin' said:HEY.....YOU....HEY!.......SASQUATCH!
Whattheheck did you do with that can of white lithium cam lube I bought to change the lifters on Jessie's XR7????
Oh, don't tell me.......![]()
65stanger said:Dammitdammitdammitdammitdammit! How many times have you got to be told that stuff goes on the shelf in the workshop, NOT the bathroom!![]()
mustangdave said:I tried to ignore the post but I must answer: yes, raising the right side of the track bar will loosen the car,tires will look shinier under the lights at Bristol if you use Meguiars Tire Shine, crabgrass is the root of all evil, and you should feed your dog every day. Now, if we could just invent a sock that doesn't leave fuzz between your toes when you take it off......
65fastback2+2 said:i thought it was we should help control the pet population and have out pets spayed or neutered.
mustangdave said:Back to the question: A 2 oz. bar of Reese's Fast Break has 5 grams of protein and does indeed taste better than Neosporin on a cracker. Now that I've helped you, what exactly is that white dust that comes off of toilet paper? I've been trying to ignore it but it's all over the glass shelf in the bathroom. Toilet paper is made from trees and I've never noticed them giving off white dust when you unroll them.
