Plug gap for best efficiency
  • Thread starter Thread starter Black1987Stang
  • Start date Start date Nov 17, 2006
Black1987Stang
1,422
Jersey Shore
Nov 17, 2006
  • Nov 17, 2006
I just picked up some Autolite 25's for my stang, has cast iron Windsor Jr. heads on it, the one I just took out of the box is at .043 gap using my feeler gauges, what should i change it too, I know stock is .054, I also have an MSD box, should I go up at all?, Ive been searching alot on here and read alot of people actually going lower to like .040-.045 gap for better performance, or at least better start-ups, idling n such (low-rpm driving). I wont be beating on it, just cruising, would a lower gap be more efficient or a bigger gap?....Im changing the plugs for a 14 hour drive ill be doing soon just for extra insurance so what gap would all of you recommend? Thanks
TomCat
412
Utah
Nov 17, 2006
  • Nov 17, 2006
I'd just stick with the .054
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Nov 17, 2006
  • Nov 17, 2006
X2, I would stick with Ford's Specs.
F
fastranger347
59
york PA.
Nov 17, 2006
  • Nov 17, 2006
yea i know i will be ostisized for this but; i have a crane hi-6,crane coil,motorsport 9mm wires and use autolite plugs @ .075 gap, the ignition has enough energy in it so why not use it??? it idles great and pulls to my 6,500 reline without missing, when i go to apower adder i will gap them at .050 and go from there
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Nov 17, 2006
  • Nov 17, 2006
Ford spec is very popular...I have used it and as of late I've used .045 with my last set and found no difference. Only thing I have noticed is that while now running a set of AR3924's ( come from autolite with a 2mm cut back strap) that the plugs are cleaner...I can't say why though, might be a little better burn, but as stated I can't say for sure at this time.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
W
New plugs, wires, dist cap and rotor, now randomly stalling
  • WhiskeyFoxTrot
  • Oct 12, 2024
Fox 5.0 Mustang Tech Oct 15, 2024
WhiskeyFoxTrot
W
Fox Spark plugs
  • Mattjhop23
  • Jul 6, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 14, 2025
Reddevil91
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
F
Resolved Stumble issue upon acceleration (1987 GT)
  • FoxDude87
  • Sep 16, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Dec 3, 2024
FastDriver
