- Feb 21, 2006
- 573
- 1
- 19
I just installed new intake gaskets on my manifold. Upon advice from a local gear head I used the plugs that came with gasket that plug ports going under carb on manifold. I think are called the heat cross over on the manifold. Was told it would run cooler with this done. Although it may impact choke operation in cold weather - since it will be a fair weather car was not too concerned.
I do now have some hesitation on take off that I did not have before. Thought it may be timing was too advanced so I reset and I still have hesitation - had to adjust idle/fuel mixture to get rid of some - but still have it. Just wondering if I can rule th cross over on the manifold as a source of the problem. Hoping I can - don't want to pull manifold off again. I'll probably pull carb and check bowls just to ensure they did not get bounced around during the install. Appreciate any feedback. thanks
