Plug indexing...am I aiming for the CCtop or the intake valve?
crazypete
All my crevices are greased.
Oct 22, 2004
930
48
Arlington, MA
Hey folks, I am indexing (and side gapping) a set of afr165 plugs with the heads off the car and I have been recieving some conflicting information on how to index them. Up till now, I've faced the strap torwards the top of the chamber so the flamefront can extend downward torwards the pistons.
Some posts say that I should face torwards the intake valve. This confused me since the valve should be shut already during ignition so there is no fuel flow through the valve at that point. Furthermore, the strap would create a shadow on the exhaust valve side. It didnt seem right
Which way would it be?
Thanks for your input
Pete
Pete - I think the side gapping is more important than the indexing in a wedge type chamber. If your quench is right, I don't think it matters much where they point -- just try to have them all facing in a similar direction for consistency. I'd turn them so the open gap faces into the chamber.
to index a plug you are supposed to have all the plugs facing the exhaust valve. but as long as you have them all facing the same way you'll be alright, you just won't get a good clean burn, unless they are facing the exhaust valve.
A "good clean burn" has a lot more to do with MANY other variables besides which way the plug is pointed. Given the importance of fuel economy and emissions compliance, if indexing the plugs helped significantly - the OEM's would do it. But they don't - because it's not gonna make that much difference. In tightly contested, strict rules class of racing where every 1/2 HP counts, you do every little thing you can to help -- indexing falls into that category. For us just dicking around trying to make things better -- you'll never notice the difference between indexed and not indexed.
In any event - give us the theory behind the necessity of having them 'pointed' at the exhaust valve.
Pointing them towards the exhaust valve? I've never heard that one. The exhaust stroke comes after the power stroke so I'd have to disagree on that one. I've heard the theory of facing it towards the intake valve. I don't think in actuality you ever even notice very much HP gain. Many people do it for piston to plug interference when running very close tolerances.
You just never hear the phrase "just dicking around" as often as you should....Sorry Mike just bored and lookin to stirr it up a bit.:D
It's days like this that I enjoy...sharing thoughts...making freinds...and yes even learning..even if just a little. What did I learn you ask? Well today I did learn if you use a lil old dash infront of the word ass then it will not be blocked by the language filter...oh happy day!!!-ass-ass-ass
Thanks Daggar once again you've taken my failure/disapointment, turned it around, and left me feeling well....mediocre :) and only mildly sad.:cheers:
Now for the Tech portion..the only thing I am willing to spend time indexing is the lable on my beer while I'm installing plugs, spend your time on bigger and better things..just my opinion.
I have used my "index" finger to point out funny things I have seen. I have also used the finger next to my index finger to gesture to others.....
ass ass ass.....don't know why I keep doing that but I better stop before Dagger puts up on of his scary.."THIS IS NOT :stick: TECH" things in big bold print.:stick:
I've always understood to point it to the exhaust valve. It allows for the spark to escape quicker or something like that so it is "pushed" right out the exhaust.:shrug: I do believe consistency is important no matter which way you do it.
Now putting it towards the intake valve might not be a bad idea. No suction from the exhaust valve and not upward movement of air from the piston to disrupt the spark.
Since the compression takes place in a closed cylinder I don't think it matters so much on if the gap (pointer) is towards the piston. It sparks in the area and combust.
I dont think we are trying to optimize exhuast efficiency here but rather combustion speed. I dont think aiming it torwards the exhuast valve is better than the random non indexed trim.
I wonder sometimes why the industry has not made deisel like high compression engines that inject and combust right away out of every car. Seems like the better way to do things.
Audi just introduced direct injection gasoline efi in Europe - directly injects the fuel into the combustion chamber just before ignition. They've been working on it for years. The system runs at 3000 psig. MUCH more efficient - better emissions - better power and best of all - helps eliminate detonation. Nothing to detonate if the fuel's not there during compression!
Indexing was NEVER about aiming at a valve --- uh, the valves are closed during compression and power stroke -- they're just like any other part of the combustion chamber when they're shut. Indexing was about 1) positioning the plug in a way that the piston doesn't close the gap in engines that run VERY tight clearances and super high compression ratios (buddy's 16:1 big block Chevy will close the gaps if the plugs aren't indexed correctly, or 2) aiming the gap the same way in all 8 cylinders so the flame front/travel/combustion pattern is similar in all 8 cylinders. It's simply not a big deal no matter which way the gap is pointing unless you've got clearance issues.
Great if you want to play with it -- but probably won't accomplish anything at all except eating up some of your time.
