plug question
  • Thread starter Thread starter mustangGT85
  • Start date Start date Sep 21, 2005
mustangGT85
264
Orange CA
Sep 21, 2005
  • Sep 21, 2005
hey guys, i was wondering if anyone could identify these 3 plugs:
they run along the same loom as the map sensor:
thanks guys
~Steve
ss93cobra
1,422
Wilmington NC
Sep 21, 2005
  • Sep 21, 2005
The odd shaped one is the test port for the eec system and it should be located right by the driver's side hood hinge. The other two are for the connectors for the engine/front end harnesses
mustangGT85
264
Orange CA
Sep 21, 2005
  • Sep 21, 2005
i'm sorry, can you explain that a little further. what do you mean by "engine/front end" harness.
mustangGT85
264
Orange CA
Sep 21, 2005
  • Sep 21, 2005
sorry one last question for now, i cant find the connector, that goes to this plug. it hooks up to the starter selonoid, and when the battery is connected, it is the only plug with juice(i used a test light). i dont know if it should plug into another plug in the harness or if it has an extension or what.
seriously, thanks a lot. i really appreciate this.
~Steve
ss93cobra
1,422
Wilmington NC
Sep 22, 2005
  • Sep 22, 2005
The two rounded plugs in the first picture go to the ignition system, headlamps, etc. Nothing will work right without them plugged in. Regarding the most recent pic., have you got another picture of the other plug in on that harness?
mustangGT85
264
Orange CA
Sep 22, 2005
  • Sep 22, 2005
yeah. i have a digi camera, so if you need any peticular pictures of anything i can go outside and take them.
~Steve
mustangGT85
264
Orange CA
Sep 22, 2005
  • Sep 22, 2005
DP
mustangGT85
264
Orange CA
Sep 22, 2005
  • Sep 22, 2005
now this isnt in a mustang, so i dont need the headlights or tail lights or side markers to work with the mustang harness, i still have the Rx-7 headlight harness hooked up. so what i'm asking is, does that plug effect my engine? or do i still need to plug it with another connector?
~Steve
wht93gtEd
29
Jersey Shore, New Jersey
Sep 22, 2005
  • Sep 22, 2005
Here ya GO!!!!
You can see, in the first diagram, that there's a +12 start for the TFI. You'll probably need this to start the car.
Good-luck.
www.fordfuelinjection.com/?p=6
mustangGT85
264
Orange CA
Sep 23, 2005
#10
  • Sep 23, 2005
  • #10
so i guess the big question is, which connector connects to plug #31.
and thanks for those 3 pictures
~Steve
mustangGT85
264
Orange CA
Sep 24, 2005
#11
  • Sep 24, 2005
  • #11
anyone?
wht93gtEd
29
Sep 24, 2005
#12
  • Sep 24, 2005
  • #12
i'm not sure I understand what you mean????
In your first picture you can see that 1 plug is brown and 1 plug is black. #31 is the brown one, as stated in the diagram. That's all I can really tell you.
Check out the link I posted above. It has everything you need to make a Ford fuel injected vehicle run. It's basically directions to make your own harness.
wht93gtEd
29
Sep 24, 2005
#13
  • Sep 24, 2005
  • #13
~Steve
This is the EGR Valve Position sensor (EVP). There's a trick to bypass it, although I've never done it.
mustangGT85
264
Orange CA
Oct 1, 2005
#14
  • Oct 1, 2005
  • #14
hi guys, i'm back with another question. but first i just want to thank everyone that been helping me. its really appreciated.
On to the question. what wires should be connected to my starter? cuz as i was down there i noticed i only had one wire running from my starter to my starter selonnoid. and there are two other bolts on there with nothing connectedd. again thanks.
~Steve
mustangGT85
264
Orange CA
Oct 1, 2005
#15
  • Oct 1, 2005
  • #15
if someone can take a gander, and look under their car for a sec, then just trace back the wires. that would be much appreciated. sorry if i sound immpatient. i think this might be the cause of my no-start problem
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
M
Connector location
  • Mike3
  • Jun 28, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 28, 2026
Mike3
M
Help Identifying Engine Harness Plug
  • FoxbodyRob
  • Feb 7, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Feb 7, 2026
FoxbodyRob
LT header id
  • djj62478
  • Feb 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
General karthief
Electrical Spark Plugs
  • jimzzilla
  • Feb 24, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 28, 2026
jimzzilla
