plugging smog holes..
my ford dealer had them in stock. i think they where like 5.00 for the pair. there the right ones for the holes, plus there threaded i the inside of the plug for some reason
my bolts are 2 3/4 inch long from teh head and liek a 1/4 inch wide ( im not good with bolt sizes) and a caurse thread.
just did this about an hour ago. that picture above (red88 RICK's) is the bolt that holds the tubing onto the heads, which is not the same as the bolt you need to plug the actual hole.
well i managed to get them in, 5/8-11 x 1", but they stick out a long ways. went in pretty tough though, i'm actually a little worrried i may have cross threaded them. i doubt it, but theres a chance. i have a feeling all the carbon build up in there may have something to do with it. anyways, definitely not the easiest place to turn a wrench so it'll have to do for now!
wow mine musta have been realy clogged up them i didnt even noticed there where threads in there ha i thought the question was whats the bolt size for the tube cause what i was going to do is bolt up the tube and crimp and weld the end.
yeah if u took those 2 bolts out u had in the pic, just yank on the tubing and it should all come right off. mine was kinda stuck on with the gasket sealer. Behind the little blocks on the tubing will be much larger threaded holes that can be plugged. just hope i used the right bolts cuz they were pretty snug and tough to get started..... oh well. need new heads soon anyways. !!!:)
I called the dealership. They said they have a "reducer" available. from how the guy described it, it fits into the hole and bring it down to a smaller thread size, then you use a normal size bolt to plug it. I'm not sure why you need this. I am going to do this delete tonight and i was just going to use the size bolts that everyone recommends.
For everyones information the part number from Ford is: F4ZZ-6E086-A. He said they were $26!
plugs
I got mine at napa, they were called thermactor plugs, threaded plug that has screws outside and in, sealed it with thread sealer with teflon. If I ever get this engine and transmission in I'll let you know how they work but that is what they are meant for.
those work, ive used about 15 of them, best little trick out there, and they were fairly cheap, only cost me a few bucks
