plugs keep fouling
  • Thread starter Thread starter dvsmike
  • Start date Start date Apr 10, 2004
dvsmike
70
Chicago il
Apr 10, 2004
  • Apr 10, 2004
This is the 2nd time in 6 months that my #6 & 7 plugs were fouled,the rest were fine. One was dry and had alot carbon build up on it and the other had oil and soot all over it, you couldnt even see the gap. Could it be Bad rings?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Apr 10, 2004
  • Apr 10, 2004
It could be bad rings, but not as likley as the valve seals, which wear out faster usually. Do a compression test, maby even a leak-down test if you can. It is most likley the valve seals, which can be replace w/o removing the head. Also, do you get alot of oil in your pcv system?
NKau
1,346
Jefferson, WI
Apr 10, 2004
  • Apr 10, 2004
May want to run a compression check on all cylinders and see if the suspect cylinders come up low. How many miles on the engine? Does it burn a fair amount of oil? Also, what kind of shape are your wires, and distributor's cap and rotor in? Just some things to look at.....
dvsmike
70
Chicago il
Apr 10, 2004
  • Apr 10, 2004
I just replaced wires,cap & rotor a week ago and the plugs were done 5 to 6 months ago. I noticed the car started running sluggish so I pulled plug 6 & 7 first cuz those were the culprits last time. My heads were replaced about 6 months ago as well. My stang has 162k and yes it uses about a quart a week.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Engine Light throttle miss
  • Dontknowchit
  • Jul 7, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
L
Engine Normal Leakdown Results (unstarted in nearly 2 years)
  • Lube
  • May 26, 2024
Fox 5.0 Mustang Tech Jun 1, 2024
Blackhawkxx
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
