  • SN95 4.6L Mustang Tech
po171 freeze frame data help
  • Thread starter Thread starter codster roadster
  • Start date Start date Dec 18, 2011
C
codster roadster
california
Dec 18, 2011
  • Dec 18, 2011
hi! new to mustangs and need alittle help figureing out what this freeze frame data means for my 1998 mustang gt
po171:
RPM:2850
LOAD VALUE:89.4%
COOLANT TEMP:185'F
56 MPH
short term fuel-trim 1: 10.1%
long term fuel-trim 1: 25%
short term fuel-trim 2: 11.7%
long term fuel-trim 2: 25%
short term fuel-trim 3: 60.9%
long term fuel-trim 3: -44.0%
long term fuel-trim 4: -39.5%
short term fuel-trim 4: 97.6%
If anyone can point me in the right direction to fix this problem i would be extremly grateful
...also my car doesnt have any trouble idleing, accelerating or starting up? thank you.
joshjwc9
1,095
17
39
Palm Harbor, FL
Dec 19, 2011
  • Dec 19, 2011
Do you have any exhaust leaks?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 19, 2011
  • Dec 19, 2011
+1 on the exhaust leaks. Also check for vacuum leaks especially around the PVC system. Do this before replacing any parts.
For lean and rich DTCs:
  • Fuel system
  • Excessive fuel pressure.
  • Leaking/contaminated fuel injectors.
  • Leaking fuel pressure regulator.
  • Low fuel pressure or running out of fuel.
  • Vapor recovery system.
  • Induction system:
    • Air leaks after the MAF.
    • Vacuum Leaks.
    • PCV system.
    • Improperly seated engine oil dipstick.
  • EGR system:
    • Leaking gasket.
    • Stuck EGR valve.
    • Leaking diaphragm or EVR.
  • Base Engine:
    • Oil overfill.
    • Cam timing.
    • Cylinder compression.
    • Exhaust leaks before or near the HO2Ss.
C
codster roadster
california
Dec 20, 2011
  • Dec 20, 2011
got the car up and couldnt see any charred black spots on the exhaust or headers. and just curious if it was leaking from where the headers mount to the heads would there be a pretty noticeable sound coming from it? ive sprayed the intake manifold and intake and pretty much the whole engine with starting fluid while it was running and it idled perfect. i also have a p0153 o2 sensor code?...which i just found out :/
  • Gulftown980x
  • Jul 29, 2026
squeak93
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
SOLD 1993 Mustang Cobra / 114K miles / Modified / Fort Lauderdale, Florida.
  • Naja
  • Oct 4, 2023
12K
Fox Body Mustangs For Sale (1979-93) Feb 26, 2025
Naja
Need Help, Car Wont Start, I've Gone Through Both Checklists
  • 93silverlx50
  • Jul 22, 2017
  • 2 3
13K
Fox 5.0 Mustang Tech Apr 30, 2019
General karthief
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
