NorthwestGT said:
I think you're right Zoomer. I actually used a little Flitz polish on one area of mine and the originals would probably just polish up pretty good. But, powedercoating or ceramic coating should look good. The problem is getting them off. There's a lot of spaghetti connected in and around the cam covers and the back nuts look like they'll be fun to get loose.
Some guy on the Corral Forums said it took him just 20 min. to get them off. I don't think so.
It takes 20-30 min each to get them off.
It looks intimidating but it's really quite simple.
I removed the first one, wet sanded it down with 320, 600, 1000, and and, 2000 then hand polished it with aluminum mag wheel cleaner (eagle one) and reinstalled it in about 3 hours one morning before going off to work. Next time I'll try using the Mothers Power Ball.
LH Removal
Remove the air cleaner assembly and outlet pipe.
Remove the LH ignition coils.
Remove the oil level indicator and tube.
Disconnect the evaporative emissions (EVAP) tube from the intake manifold.
Remove the positive crankcase ventilation (PCV) tube.
Disconnect the LH variable camshaft timing (VCT) solenoid electrical connector and detach the 2 wiring harness pin-type retainers.
Detach the 2 wiring harness retainers from the valve cover stud bolts.
Loosen the 15 fasteners and remove the LH valve cover and gasket.
RH Removal
Remove the RH ignition coils.
Detach the wiring harness retainer from the engine front cover stud bolt.
Disconnect the RH variable camshaft timing (VCT) solenoid electrical connector.
Disconnect the positive crankcase ventilation (PCV) tube from the RH valve cover.
Detach the 4 wiring harness retainers from the valve cover stud bolts.
Loosen the 14 fasteners and remove the RH valve cover and gasket.
No offense to anyone but the difficulty level is only one notch above replacing your intake.
