Hahaha chrome adding weight88GT17MA said:chrome will add some weight to the piece, polishing can happen but is not easy because there are many grooves and small crevices in a head unit.
.....we're talking ounces here, not pounds. Him running his car out of windshield washer fluid when it was already only half full would more than make up the difference in weight he'd gain. As for polishing it....it's a bitch, but worth it if you're into the 'bling, bling'. My advice would be to start with a 180-sandpaper and work your way to 2000-wet. The start with the levels of polishing compound from there....it'll come out like glass. But remember....the upkeep on it is going to be just as demanding, so keep that in mind before you go hogwild.Gearbanger 101 said:Hahaha chrome adding weight.....we're talking ounces here, not pounds. Him running his car out of windshield washer fluid when it was already only half full would more than make up the difference in weight he'd gain. As for polishing it....it's a bitch, but worth it if you're into the 'bling, bling'. My advice would be to start with a 180-sandpaper and work your way to 2000-wet. The start with the levels of polishing compound from there....it'll come out like glass. But remember....the upkeep on it is going to be just as demanding, so keep that in mind before you go hogwild.
What he said but more tactfully.
Clear Coat + Heat = Caramel CornPaul Perreca said:You know, instead of upkeeping it, I wonder if you can just clear it after polishing is done - Than you dont have to keep it up lol - just wash it lik normal - i'll try this on a piece of aluminum at my shop and get back to you lol
Paul Perreca
