polishing brackets
  • Thread starter Thread starter 83Mustang427TT
  • Start date Start date Jul 10, 2006
83Mustang427TT
162
  • Jul 10, 2006
Ok guys now I have heard and seen polished brackets like the P/S bracket ...so I tried to do it myself ..well besides the fact that my hand hurts heres a pic ..I still have a lil bit of cloudyness? in it how do I get rid of that?
pb_paulie_b
894
Chaptico, Maryland
Jul 10, 2006
  • Jul 10, 2006
What did you use? Cloudiness is common with this piece. It because of the sad quality of the metal.
Here's one that I did...PB
87ttopstang
342
Ontario, Canada
Jul 10, 2006
  • Jul 10, 2006
Yup...like he said, that piece will be a little cloudy due to the metal quality. You might want to try tripoli again, then re-buff it with the white compound to bring out the shine.
fidstang
307
South Lansing
Jul 10, 2006
  • Jul 10, 2006
What all is needed to polish parts? Compounds? Tools?
Cougar5.O
87
Manchester NH
Jul 10, 2006
  • Jul 10, 2006
These sort of surface imperfections are common in casting grade aluminum that has a lot of impurities added to aid in flow (filling the casting) & release from the casting (lubricants). It is in no way indicative of the quality of the metal.
pb_paulie_b
894
Chaptico, Maryland
Jul 10, 2006
  • Jul 10, 2006
I beg to differ. It's basicly pot metal. The cheappest of the cheap.
Cougar5.O
87
Manchester NH
Jul 10, 2006
  • Jul 10, 2006
Well, I design castings for a living so maybe I do know about casting grade aluminum.
pb_paulie_b
894
Chaptico, Maryland
Jul 10, 2006
  • Jul 10, 2006
Then you already know it's cheap.
billison
I like tinted tail
2,607
1,094
184
stl
Jul 10, 2006
  • Jul 10, 2006
how the heck you polish like that, crap i'll do the whole car like that once i get it running
pb_paulie_b
894
Chaptico, Maryland
Jul 10, 2006
#10
  • Jul 10, 2006
  • #10
Lots of time, lots of patience. After a while you learn what compounds and wheels to use from experience.
Things like the P/S bracket, it's important to take time in the sanding to get the surfaces flat. On mine I final block sanded with 600 grit.
billison
I like tinted tail
2,607
1,094
184
stl
Jul 10, 2006
#11
  • Jul 10, 2006
  • #11
talk to me like i'm a dummy or a chevy driver, do i spit on it and swirl it around , thanks
pb_paulie_b
894
Chaptico, Maryland
Jul 10, 2006
#12
  • Jul 10, 2006
  • #12
I normally start with a real good cleaning of the part.
Then the sanding begins. I use a 6 inch random orbit sander and a expander wheel where ever possible, but much has to be done by hand.
I go from as low as 80 grit to as high as 600 in extreme cases.
Example. I'll go in stages from 80 to 100 to 180 to 220 to 320.
After all that the buffing part is easy. I normally start with a 6 inch sisal wheel/ black or brown compound on a 3/4 hp buffer and end with a spiral sewn buff and blue or white compound.
You can take an ugly piece of aluminum that someone took a grinder to...
And make it look like this...
Cougar5.O
87
Manchester NH
Jul 10, 2006
#13
  • Jul 10, 2006
  • #13
It may be cheaper than billet, but you can't cast pure aluminum - it's way too sticky. Machined billet brackets would be way too expensive for a car maker.
BTW polishing novices - DO NOT take off too much material when working with castings - if you do you may expose small air bubbles just below the surface of the casting and they don't look good at all once exposed.
I got a nice 8" grinder and with some spiral sewn buff wheels & a few compounds I can get a good shine once the surface is smooth enough to start the final polishing (sanding described above by pb_paulie_b).
83Mustang427TT
162
#14
  • Jul 10, 2006
  • #14
I did mine by hand ...I got some sandpaper probably 120 grit sanded down the ridges then I used white polishing compount in the green can its for car finishes made it look nicey nice
ChromdOutDubs
268
Tavares, Florida
Jul 10, 2006
#15
  • Jul 10, 2006
  • #15
LOL, when i saw paulie polish stuff a while back, it inspired me to go out and buy some stuff, liek 2 nights ago i got some compounds and some wheels for my dremel and started polishin some random things, it actually works pretty good, i was using the red compound, i think its for high gloss.... not positive. The stuff the paulie does is amazing.... im gonna go buy some wheels for the table grinder thing.
-AJ
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jul 10, 2006
#16
  • Jul 10, 2006
  • #16
Just keep at it and you'll learn the tricks of the trade..I use 3" buff wheels on a high rpm grinder with white rouge...never usually go beyond 320 sanding and a quick scrub with 400 and a palm sander. For really good finish try to keep your movements either back and forth or up and down...not circles, this includes both sanding and buffing. Some pcs can only be taken so far, and lighting will have a huge impact on the overall appreance so don't be overy concearned if your's is not perfect under certain lighting...it will neveralways look perfect.
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
D
Power steering pump bracket with A/C
  • Dczookster
  • Apr 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2025
rednotch
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
