polishing tailpipes..
  • Thread starter Thread starter 808Gt
  • Start date Start date Feb 10, 2008
808Gt
115
Hawaii
Feb 10, 2008
  • Feb 10, 2008
sorry if its in the wrong section, but search and cant seem to find an answer... but I wanted to know how to polish an aluminum tailpipe, I got flowmasters and wanted to clean them up...
would using mothers ball work?
4G-KDMP
935
CA
Feb 10, 2008
  • Feb 10, 2008
Most tails that you see are stainless rather than alumimum, i think.
the power ball with the right type of polish should bring that shine back.
foxmustangman
196
Idaho
Feb 10, 2008
  • Feb 10, 2008
I use this foaming scrubbing bubbles stuff. It works pretty dang good.
Another really good method (i've done this) is to take just regular dishwashing soap and water and scrub one direction with steel wool. It got all the tar and road crap I had on my pipes off and shined them up pretty good!
808Gt
115
Hawaii
Feb 11, 2008
  • Feb 11, 2008
ok, kool thanks...
yea it is stainless lol, but ill try the mothers ball an steel wool, do you know what grade of steel wool, like 00?
blackened88lx
Connecticut
Feb 11, 2008
  • Feb 11, 2008
I dono if I'd use steel wool on stainless. If you're going to, use the finest, 0000. I haven't polished a lot of stainless stuff, but it seems real fragile. I would try it by hand with mothers or something first.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Feb 11, 2008
  • Feb 11, 2008
I just use my wheel cleaner it works fine. I just go over them every car wash with the wheel brush.
Flavadave4
1,044
21
49
Utica, NY
Feb 11, 2008
  • Feb 11, 2008
SOS pads are awesome for stainless. Run them under water, they get soapy and have at it! They can be found in the kitchen cleaner isle of just about any supermarket...heck, check under the sink you might have some already!
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Feb 11, 2008
  • Feb 11, 2008
The SS pads work but you wont get a polished or mirror look, just a clean SS look. To truly polish them, your going to need sand paper, polish, probably a buffing wheel and countless hours. Depends how motivated you are and what you really want!
R
Rock777
195
Troy, IL
Feb 11, 2008
  • Feb 11, 2008
Can't believe nobody's suggested it yet, but NEVERDULL!! It works awesome. It will clean up any tar, oxidation, and any other impurities. It will clean them up and give you a clean, new looking pipe. If you want to shine them like chrome, you will have to use other methods after the NEVERDULL, but it will clean them up relatively easy.
pavich91
18
#10
  • Feb 11, 2008
  • #10
never dull is good, but I just use very fine steel wool, then a polish. mothers works good. Just use you hand to polish, and keep goin until the black goes away. SoS works god too aswell. Sand paper was mentioned, thats the best way but make sure you dont go to heavy on it. Mabey use 1000-1500-2000 then a polish. But like I said up top...steel wool works great and its cheap and wont do any harm unless you have cheap plated chrome tips.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Feb 11, 2008
#11
  • Feb 11, 2008
  • #11
The sand paper will take time. I had some tails I was going to use, and started at them with sand paper. After about 6 hours or so they were clean looking and had a dull shine, but for a mirror finish you will need a good amount of time, and skill. I didn't have the patience for it, so I sold them!
TRWXXA
190
RIGHT BEHIND YOU!!!... Made you look.
Feb 11, 2008
#12
  • Feb 11, 2008
  • #12
If you jsut want to clean them up and make them look good, then Scotchbrite pads and WD40 will do the trick. Follow that up with some Neverdull, and they'll look real good.
If you want a mirror finish then prepare to work you nuts off. 0000 steel wool and then finer and finer grades of sandpaper, followed up with some kind of mechanical polishing.
foxmustangman
196
Idaho
Feb 11, 2008
#13
  • Feb 11, 2008
  • #13
really WD40? I'll have to try that one...
808Gt
115
Hawaii
Feb 12, 2008
#14
  • Feb 12, 2008
  • #14
ok, thats for all the ideas...
does anyone have like before and after pic... my tailpipes are stainless steel all the way no chrome tips, dont really like chrome :-/
TRWXXA
190
Feb 12, 2008
#15
  • Feb 12, 2008
  • #15
Works like a charm. It's a great solvent, as well as a lubricant.
WD40 is right up there with duct tape as far a usefulness goes.
If it shouldn't move, but does -- use duct tape.
If it doesn't move, but should -- use WD40.
You can use them together too -- WD40 removes the adhesive residue left when you pull the duct tape off.
pavich91
18
#16
  • Feb 13, 2008
  • #16
I just bought some 2 1/2" tips and they came lookin pretty ugly. I almost finished one. I will post a pic of the 1 that I did and one of the other that's untouched.
SVT32VDOHC
3,501
28
119
Motor City
Feb 13, 2008
#17
  • Feb 13, 2008
  • #17
A friend of mine used that on his aluminum dirtbike frame. Looks close to chrome.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
314
281
134
Apache Junction, AZ
Feb 13, 2008
#18
  • Feb 13, 2008
  • #18
Turtle Wax brand chrome and metal polish has always worked perfectly well for me over the years. It even took all of the primer overspray off of the tailpipes on Frankenstang's Capri.
P
Tailpipes for '88 GT
  • pindude80
  • Apr 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 13, 2025
pindude80
P
D
After Market fuel rails with Stock fuel lines
  • dropteeth
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
2000xp8
G
1982 Mustang GL 5.0 single to dual exhaust conversion
  • Guyton
  • Jun 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 1, 2025
limp
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 11:42 AM
limp
