  • SN95 4.6L Mustang Tech
popping & clunking sound ???
  • Thread starter Thread starter rispoli_23
  • Start date Start date Dec 3, 2010
rispoli_23
182
  • Dec 3, 2010
i noticed last week when i pull forward or back up i hear a popping sound and can slightly feel it in my shifter and it is getting louder i also noticed it does it real bad if im going to slow while in gear and when my car starts to jerk i can hear the popping and clunking sound ... my car has never made that sound before when that happens .. any suggestions guys oh and it only does it once when u back up or pull foward ummm like if u back up it will do it but to make it do it again u have to pull foward and then back up again if that makes any sense .. sorry
thanks
trinity_gt
3,125
81
99
Canada
Dec 3, 2010
  • Dec 3, 2010
Check the driveshaft U-joints...now.
6T9_CHARGER_RT
125
S.I.N.Y.
Dec 3, 2010
  • Dec 3, 2010
....or trans mount
03machone
26
  • Dec 3, 2010
Do you know if it is coming from the rear-end or trans?
merc123
420
North GA
Dec 3, 2010
  • Dec 3, 2010
Could be the pressure plate also. Mine was doing it when the fingers in the pressure plate weren't allowing the throw out bearing to not engage squarely so I had half clutch engagement. It would only do it in first gear (steepest ratio) and when I was going slow. The car would jump and make a clunk sound like it was coming from the transmission almost like a loose input shaft.
As soon as my new clutch/pressure plate goes in I'll know for sure. I do know that it didn't happen before the clutch started to shudder.
Secret Squirrel
12
Shreveport La
Dec 9, 2010
  • Dec 9, 2010
could be ball joint worn out. word is they last about 90,000 miles. If it is, get it checked and replaced asap. A ball joint failure will do major damage at low speeds or result in a very bad crash/ death at high speeds. If your mustang is lowered with the stock A arms they could wear out a lot sooner. If your boot is ripped on a ball joint with no way to refill with grease it is a time bomb.
Also on the 03 mustang ford used a metal shaft that was too long on the rack. It would make a popping/grinding sound when slow motion turning, bumps, and backing up. They can be grinded down or you can buy the replacement part from ford. Not sure if this affected any other years.
Secret Squirrel
12
Shreveport La
Dec 9, 2010
  • Dec 9, 2010
just reread your post +1 on the trans & u - joints check
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
