Popping sound from rear
[Twitch]
168
Montreal
Recently, I've been hearing a lot of popping sounds coming from the rear. This usually happens when I am from stoplight and I start moving. I hear pop pop pop. This also happens when driving slowly around in a parking lot looking for space, when I turn, I hear the pops.
I have a Ford Bullitt Suspension kit (Spring shocks, struts and swaybars) and rear MM LCA-5. The chassis side is a 3 piece urethane bushing, the axle side is a teflon filled sperical bearing. The LCA have been purchased and recently installed about 2-3 months ago.
When I first got the LCA, I rearely heard any popping, not it's all the time.
I am wondering if this popping is from the LCA and if it is normal?
I have a feeling that the only thing that it sounds like you haven't replaced are the bushings on the differential that the upper arms mount too. I pretty much about have the same setup as you there and I get a knock/popping sound like somethings rocking around and loose and those are the peice I haven't replaced. I think someone made a post about the same thing that he did that and it's gone now.
A couple of years ago, my car was making sounds from the rear. Not popping, but more like banging, and kind of loud. Turned out it was a loose bolt on an upper control arm.
Yes, passenger side. I got under it and had my daughter bounce the rear up and down, and I could clearly tell exactly where the sound came from. Then I could move the uca around and make the sound. Tightened the bolts and it's been quiet since.
Hmm, I was under my car, in a pit and tried to move the UCA, they wouldn't move. I'll try to tighten them just to be sure.
That was me. I had a similar situation except mine did it on curves and bumps. Turns out my UCA bushings on the pumpkin were shot. I replaced the bushings with stock ones and used FRPP UCA's, problem solved. BTW, buy the bushing install tool. Check your torque boxes too.
Good new guys! Finally found out what was wrong.
I was trying to replicate the sound, so I stood up on the driver side rocker panel and jumped up and down. Sure enough, the clunk/pop sound was there, at the rear wheel, nowhere close to the UCA.
Jack the rear up, inspected the MM LCA on the axle side, seems good, no visual gaps. Specs says to torque it 71-97ft-lbs, started on the lowest setting and the bolt and nut was spinning.
This is why I like to do all my work myself, so I can do everything right the first time. The mechanic must have never torqued it down to spec. So I torque both LCAs to be sure and voila, the clunk/pop is gone:nice:
Beauty eh? :D
Seriously, thanks for reporting back. Too often, someone defines a problem, asks for help, and disappears. We never know if or how the problem was solved.
:nice:
