Popping Through Intake
  • Thread starter Thread starter 1987BlackFox
  • Start date Start date Mar 10, 2017
1987BlackFox
  • Mar 10, 2017
I have a 87 gt with speed density and I'm needing help. When I go to hit the gas it backfires through intake a couple times then takes off it doesn't matter if it's hot or cold. It had new plugs,wires distributor cap rotor and iac, and no vacuum leaks that I can find. I also have checked tps to make sure it's in range. Any other suggestions would be really appreciated.
CarMichael Angelo
8,909
234
Birmingham, al
Mar 10, 2017
  • Mar 10, 2017
It's popping through the intake.?
Or you got mad because it was popping, took the intake off, and threw it away?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Mar 10, 2017
  • Mar 10, 2017
pop tarts?
Admin Dude
Jan 4, 1985
43,564
21,734
234
Box behind Walmart
Mar 10, 2017
  • Mar 10, 2017
TPS or vac leak
General karthief
Mod Dude
Aug 25, 2016
28,133
10,750
213
polk county florida
Mar 10, 2017
  • Mar 10, 2017
Just for fun run the codes?
1987BlackFox
  • Mar 18, 2017
Thanks for the help looks like it was the tps
stykthyn
5,232
2,652
223
gainesville
Mar 18, 2017
  • Mar 18, 2017
Vac leak and I'm going to go with possible bad timing for 500 Alex.
Admin Dude
Jan 4, 1985
43,564
21,734
234
Box behind Walmart
Mar 18, 2017
  • Mar 18, 2017
Answer right in front of you and you still guessed wrong. Put the cork back onto the end of your fork and finish your applesauce.
Reactions: 5.0Droptop
stykthyn
5,232
2,652
223
gainesville
Mar 18, 2017
  • Mar 18, 2017
I'm just that guy. Didn't see the culprit in the above post and was just too lazy v to retract my answer. Can I has more applesauce now?
1987BlackFox
#10
  • Apr 10, 2017
  • #10
Well I thought it was thew Tps and had no such luck. Ive checked vacuum and its good ive replaced IAC, plugs, wires, cap, fuel filter thinking there might be water trapped in system and also checked timing and its good. Any other ideas would be really appreciated
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Apr 10, 2017
#11
  • Apr 10, 2017
  • #11
Step#1. Run the codes.
86-88 don't have a check engine light so you'd never know what's going on
1987BlackFox
#12
  • Apr 10, 2017
  • #12
I ran codes and KOEO and got code 82 and did a KOER and got cooling temp sensor out of range, 42 oxygen sensor out of range. so wondering if when i fix these issues my problem will get corrected
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Apr 10, 2017
#13
  • Apr 10, 2017
  • #13
Did you run codes with engine hot? If not, you get a false coolant temp code.
But yes, o2 sensor and coolant sensor codes could be the issue. Popping through intake is sometimes a fuel mixture issue
CarMichael Angelo
8,909
234
Birmingham, al
Apr 10, 2017
#14
  • Apr 10, 2017
  • #14
Did you ever bother to look back at the title and fix the damn grammar?
FIX THE GRAMMAR!
Reactions: 1987GT and RaggedGT
CarMichael Angelo
8,909
234
Birmingham, al
Apr 11, 2017
#15
  • Apr 11, 2017
  • #15
Awww,....what the hell,...I'll do it...
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
