Try
4429K413
That's one of many. That's a brass fitting...if you wanted stainless steel, I can dig you up one of those.
If you want to try searching, search "pipe fittings", then select material, then "hex bushings" and then scroll down and select the size " 1/2npt to 3/8npt" and it will give you a few options. I just selected your basic cheap brass reducer fitting
