If I were to throw on a set of stage 2 ported heads by Total Engine Airflow and a set of cams from MHS probably stage 2 along with a Hardball'r intake, would I make power out to about 6500 maybe a tad bit more?
If you are pulling the heads, its not that much more work to pull the rods and pistons. Swapping in a set of 4V pistons with an intake notch and cheap forged rods is a night and day difference in what you can do cam and power wise.
Any 4v piston would do? Wouldn't that raise my compression to around 12:1 as well?
The shortblock would be stock so I dont think what you suggested would work. lol. I chose the hardballr cause my buddy has one installed on his gt and the car is just sitting with a laundry list of things that need to be done to get it road worthy so I figured I'd take whatever I can get for free.
I just want something that will give me a little more power and let me rev higher since Ill soon be replacing my 3.73s with 4.10s.
Actually its around 11.5-11.8:1 and is the perfect compression ratio for a real street 2V on pump gas if you cam it correctly.
that makes me want to pull my heads off and weld the chambers, im only a tad over 10:1![]()
Deck the heads 30, deck the block 20, run a flattop piston, and its near 11.5 with the NPI but you better blueprint everything.
Put a set of P.I. heads on and throw them npi's away...........
the heads have 5 off them, could i just weld up the chambers, and smooth it out to make the compression higher?
