Porting e7/lower intake require afpr/injectors?
  • Thread starter Thread starter DTT92LX
  • Start date Start date Oct 6, 2004
DTT92LX
185
Downingtown, PA
Oct 6, 2004
  • Oct 6, 2004
I'm porting my e7s and lower and was wondering if I need to consider the fuel system at the same time. e7s will hopefully flow 180-200cfm and same with lower. Think I'll need to upgrade my stock fuel system to keep up?
Thanks,
Dave
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Oct 6, 2004
  • Oct 6, 2004
You dont have to. But a set of 24# injs and a AFPR & bigger pump wont hurt either.
ninety15.0
1,336
  • Oct 6, 2004
depending on your cam and exhaust and other things, I think the 24's would be a little overkill, but the afpr and bigger pump would be a good idea.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Oct 6, 2004
  • Oct 6, 2004
thats true, I had a bigger cam with my ported e7 and ported lower.
DTT92LX
185
Downingtown, PA
Oct 7, 2004
  • Oct 7, 2004
Do you think it'll run lean if I stay with the stock fuel sys?
DTT92LX
185
Downingtown, PA
Oct 7, 2004
  • Oct 7, 2004
tmoss said:
Getting 200 cfm from a stock lower is not easy.
You would know, Tom!
I dk if it'll hit 200 cfm but I guess what I'm really wonderin' is if the stock fuel system is going to provide enough fuel relative to the maximum airflow possible thru porting stock parts.
What will a "better" pump do? In other words, what can't the stock pump do that a better pump can?
Dave
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Oct 7, 2004
  • Oct 7, 2004
Put in a better fuel pump, use the 19# injectors. Getting 200 cfm from a stock lower is not easy.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Oct 7, 2004
  • Oct 7, 2004
The stock pump may be OK if it is delivering it's full fuel amount and pressure. A 156lph/190lph pump is pretty cheap - less than $100 delivered if you shop right and have the cash.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Oct 7, 2004
  • Oct 7, 2004
Stock inj will be fine, AFPR is a very good idea, and a fuel pump is a must if you have a stocker. It is only getting weaker over time (I found this out the hard way).
M
mackey
1,284
Beverly, Massachusetts
Oct 7, 2004
#10
  • Oct 7, 2004
  • #10
I have a completely stock fuel system on my H/C/I car. I am putting in 24lb injectors and 80mm maf this week. I think it is time for AFPR and Fuel pump. Don't you think so?
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Custom tune?
  • Nostang25
  • Jul 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 17, 2025
FastDriver
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
