  • SN95 4.6L Mustang Tech
porting pi heads?
  • Thread starter Thread starter blown4_6
  • Start date Start date Mar 13, 2007
blown4_6
35
PA
Mar 13, 2007
  • Mar 13, 2007
I was wondering if any of you guys ported and polished a set of these heads? Im having mine done mid April and just wondering what the hp gains you are seeing. I was going to buy aftermarket heads but the machine shop I deal with here in PA said he can easly get them to flow the same or outflow the aftermarket versions. Im also changing the valves to stainless while the motor is apart.
Stan Weiss
347
Philadelphia, PA
Mar 13, 2007
  • Mar 13, 2007
# Bigger is not always better ( — Flow Velocity or the speed of the air through the port is just as important.
# We want the best flow numbers with the smallest port volume and the highest velocity.
# Remember to compare all flow numbers. — Low lift flow does help performance.
# Looking at flow numbers near or above max. Valve lift is meaningless. Look for the best average flow at mid-lift
blown4_6
35
PA
Mar 13, 2007
  • Mar 13, 2007
I didnt say bigger is better, I was just wondering what kind of numbers you guys are seeing. Im leaving the porting up to him, hes built over 25,000 race motors while in buisness, afterall thats why Im paying him to do the work. Check out his site loots of cool videos on porting and engine dyno pulls. http://rcsoa.com
Stan Weiss
347
Philadelphia, PA
Mar 13, 2007
  • Mar 13, 2007
Sorry. I was just replying to the "outflow" in the quote above.
tomustang
Psychotic Member
3,434
McLean Hospital
Mar 13, 2007
  • Mar 13, 2007
Stan does point out good info though, alot of machine shops out there including the place you want to go to is set-up and designed to build pushrod engines, which are very different compared to the 4.6L heads on the bench, I've heard of shops claim they can port anything and end up ruining the heads from over porting them because they followed 302-351/350 porting techniques
make sure the guy you're going to knows about SOHC porting
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
G
Anyone Extrude Hone or Flow Bench Speed Pro Heads?
  • giddyup306v1.1
  • Mar 1, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Mar 29, 2026
2000xp8
