Posi Q's
I just wore out my posi. :notnice: I was at the track last week when a man came up and told me i was only spinning one tire. I kinda noticed when i had a lot of rubber on one finder and very little on another. But sometimes both tires spin. Either way i have decided that i am goin to get a new posi. I drive my car every day. Should i go locker, limited slip, or jus rebuild this one? Waht kinds of posis' have u guys been happy w/? Also if i do replace the posi i am thinkin i should get some new axles and berings. If i get all this what spline should i get. I am totally clueless on rear ends. :shrug: Any suggestions will help. Thanks
The cheapest way would be to rebuild your traction lock. 50resto has a kit for $44.95. Otherwise, I'd get a 31 spline Auburn or Auburn Pro, and a set of axles, and be worry free.
What I don't like is that the Auburn differentials aren't rebuildable. They are a cone style locker, not a clutch plate style.
You could always get one of those ECTED ones. Regular limited slip, then spool at the flick of a switch (not cheap tho).
FWIW...depends on the cash flow and future plans....rebuild the Trak-Loc with 4 clutches & F-150 S spring and it'd be plenty stout for you mods...and a hella lot cheaper too... :D
Just another opinion...
Yea i did the rear end fluid when i had the new gears in. It is wierd though. Its only sometimes both tires dont spin. Not all the time. With the radials pumped up they both spin. It is when i let them down to 15 psi at the track that it starts havin problems. But i would say they spin 1 in ever 3 or 4 burn outs.
Thanks kid that owned the car before me had gears put in and said it only does one wheel burn outs so ill have to order that stuff. I know you could rebuild tem but wanted to get some part numbers. And is the f150 spring better and can it be put in with the diff. in the car. thanks jay
The F150 is just a beefier spring for more tension...When I did mine I used the stock spring and an extra clutch as in the link, it makes it a tad stouter...
Doing the spring with the dif in the car?? Got me on that one.....If your lying on your back that could be a pain as you have to dub around back and forth getting the shims right...
