posi
i have a queston i know is easy but i'm not sure what the best way to fix it. i was at milan drag way sat night for a import vs domestic night. and i had the 1 wheel peel going on. i ran 14.6 with a bone stock 93 gt the only thig it has is a centerforce clutch. what the best way to get both whells to start working for me? i seen a crap load of use 8.8 posi on ebay. will that work or do i have to buy a brand new one and pay out the ass for one? there was a complet rear end with an aubern posi w/ 373 for 250$ and there were alot of other's for under 75$ for just the posi. and help would be great thank's
1. Drain some of your differential fluid and see how it looks. If it is thick, dark, stinks, and has a gritty substance suspended in it, change it and your traction-lok may start working again. Use a good fluid and do not add extra friction modifier.
2. If the fluid looks clear and clean, or if the fluid change doesn't fix it (it did for me), buy a $50 Ford 8.8 traction-lok rebuild kit from Summit Racing and install it. This would be a good time to go to aftermarket gears as well.
Good luck.
If you can get a complete rear end with an Auburn and 3.73's jump on it. Like NOW! A new 8.8 from Ford racing with 3.73's, stock dif and 28 spline axles is anywhere from $800 to $1000. Also $75 for the dif isn't bad either. I think I paid $250 for a new one last year.
Throw a set of Drag Radials on that with 3.73's and you'll notice a huge difference.
your better off getting it rebuilt while you have the cover off... and even maybe some gears who knows :shrug: but either way getting it rebuilt will help the car out anyway because if its not working its because somethings broken/wrong lol
with a rebuilt traction lock u will get posi for a little while and the it will end up in 1 wheel peal down the road. thats why its named TRACTION LOCK, its still a limited slip but a little better. if your going to tear it apart put a aburn posi unit or something like that in with gears. i had mine rebuilt and it lasted about a month of pure posi and now it does whatever it wants to do. i wish i would of got rid of the trac-lock. pay close attention to peoples cars some use ford trac-lock others use aburn, eaton, ect, with 31 spline axles. thats my opnion. if you can get a rear end for $250 with all the goodies jump on it. but deals are like that all over.
next option is a ford 9in direct bolt ins there selling now for mustangs. there like $1100 plus the cost of a pig, which it like $250-350 with any size gear u want. that would be the best bang for your buck. and you wont have to worry about breaking it.
