possible 3G issue?
egan_gt
37
hibbing MN
I just got done doing the 3G alternator upgrade on my car last week and I thought everything went great till last night. It was the first time I have drove it at night since the upgrade and going down the road I noticed my headlights flickering. I looked at my instrument panel and it was flickering also. The only time it did it was when I was on the gas, at idle they didnt flicker a bit. So going down the road accelerating they would do it and stopped reving the motor it would do it. Im really confused. I dont remember it ever having this issue before the swap. Any help would be great. Thanks
I just did the same upgrade a couple days ago. I had a symilar problem, here are some tips:
Make sure that the small black/white wire is connected snug and not loose on the alternator. Mine was losse and my amp light on my dash would flicker when I hit the gas. I first used a small female electrical connector but then bought the correct female connector made for the atlernator, you can buy one or find one from a junk yard.
Also make sure you upgrade you ground wire to 4 gauge, I drove my car without it and it had some charging problems. I kept my original ground wire that goes from the rear side of the driver side head to the fender wall. I added a 4 gauge wire to the top of the motor(upper intake to lower intake bolt) to the chassis.
Also did you upgrade your alternator wiring? I used a 4 gauge wire with a 150amp fuse to connect the stud on the alternator to the positive of the starter relay.
Good luck
yep, I did all of the above. I ran 4ga from the alternator to the battery w/ a 130amp inline fuse. I then added 4ga from the intake to the firewall and I also snipped a harness from the local salvage yard for the factory pigtail. I bought a new alternator from the parts store in town. I cant remember what application we ended up looking it up for? It is a 130amp though. The 86's are different than all the other years for wiring it so I went off a buddies that had already been converted before he bought it and he's had no issues. Do I need to add another ground somewhere? Otherwise could the voltage regulator possibly be bad on the new one? I havent had a chance to really check it out yet. I was gonna check connections and voltage at idle and when im revving it up. It still just boggles me at idle its fine and under load it flickers. The battery seems fine, Ive shut it off and started it a couple of times, so it seems like its charging. Ill stop rambling on now!
