Post 67 Coupe Pics
Dukeboy
230
Winter Springs, FL
Im looking for good pics of a 67 coupe. Im particularly looking for cars with body kits, or aftermarket rims (especially torq-thrust IIs). If anyone has any of these, id be appreciative, for im looking to purchase a 67 and wonder if i can achieve the desired look on it.
Thanks
hope this helps
attachment.php
attachment.php
Thanks for the reply. I have a 351w stroked to a 377, c4, 9inch 33 spline axles, preformer heads,12:1 etc , etc.
The motor is curently out of the car getting better heads and cam. (lowering the compression a little) so I can afford to drive it on the street. I hope my new heads and cam get it into the high 10's, if not I'll order up a 100 shot.
btw That's a good looking 67. I love the rims and I like the way the hood looks. I just don't know if that hood will clear with my set up (if I put a kit on it). Thanks Thomas
Yeah I know it's only a half inch, but the carb already hangs out of the hood without a air cleaner on it. I just wish I had someone locally to look at and measure.
I have a ugly 429 boss style scoop on it know (was on the car when I bought it)and it just does clear with a small 8inch flat bottom air cleaner. (cleaner is only on while cruising).
i could measure tommarow from the oil pan to engine line to the top of the cowl if that will help you out.
let me know
Rich
I just read your sig alittle closer and realized you have a roller 302 block so you couldn't use the cam I have for sale. It's a flat tappet lunati, if ya know of anyone that would be interested.
If ya want to measure it, I would appreciated it. I don't know if a 302 block set's like a 351 but I'm sure it would probably be close. I'm really not in a big hurry, I've got to save alittle while before I can get the hood. I've already spent more than I should freshing up the motor. So if you get time let me know the measurements.
Thanks Thomas
68 & 00 GT said:
how about a 68 ?
your car's looking pretty sweet dude! How did you change out the side scoops? Did you do the body works? Give me the scoop, thats one of the thing i was wanting to change. Oh wait---its a 68..durrr. Still, anyone tried to change the scoops?
