post ur motor combo and ur dyno/track results...
Roadblock
208
VA
i'm starting to shop around and so far i really like the AFR 165s and 185s....i was wondering what intake and cam would be a good compliment with nitrous in the future?????
AFR 165's, FTI cam, Performer RPM intake, #30 injectors, 1 5/8 un-equal length shorties, 2 1/2 exhaust, 76mm maf, 70mm tb. 303rwhp 332rwt. Trap speeds at 108.8, both untuned. Bought nx kit, sold before ever used it though, was expecting around 11.30's@120+ with 150 shot. Decided to get there and beyond hopefully n/a with a 351 stroker.
Its all about suspension that is what will get you your 1/4 mile times. but here is what my car has. My car made 277hp/313tor to the wheels. This is untuned. I never had it tuned, but the car went 12.73@105
(engine)
stock short block,edelbrock heads 1.90 valves,b-303cam,1.7 rockers,cobra intake,65mm t.b.,C&L 73 mass air meter,24Lb injectors,Paxton fuel presseruse regulator,17*of timming,K&N cone filter,Mac long tubes,prochamber H-pipe,& Mac dumps,pulleys,msd6al,master blaster coil,Ist air adjuster.
(Drive train)
Tremec 3550 trans,steeda shifter,cobra clutch,aluminum drive shaft,4:10 gears,31 splin axels,rear end cover, arbun diff.
(Suspension)
Darg lanch kit,Strange Adjustable struts,Lakewood 50/50 shocks,HPMS megabytes control arms upper & lower, removed sway bar,ET streets 26/10.5/15 and,skinnies,Battery move to the rear.
1986 Mustang GT
357 shortblock,Track Heat Heads (Trickflow),Victor Jr.,750 Speed Demon,BBK 1 3/4 Headers,BBK H-Pipe 2 1/2 inch.,Flowmaster mufflers,NOS Cheater Kit (150 shot),Crane Cam (same as Trickflow stage 2),D&D K-Member and A-Arm kit (150bls off front),C4 full manual w/4.10 gears,10inch slicks.
I haven't got the car broken in yet,but please guess what my times are.
I think they should be in the low 11's or high 10's but I'm not sure.
