Posting up the same old question
  • Thread starter Thread starter leathernotch
  • Start date Start date Mar 12, 2007
L
leathernotch
41
  • Mar 12, 2007
High Idle
After head install, of iron gt 40's. Car idles at 800 cold once she warms up the car doesn't go below 1400, revving causes the idle to stick and it takes awhile to come back down. Vacuum when the car is cold (800to1000) is about 10 or below. Went through top-end and replaced all gaskets. No change. Why would the car idle correctly when cold?
The car idled at 1400 before we went through and replaced all of the intake gaskets and adjusted valves when we finished she idled the same no change same rpm at 1400 when she is warm. So it has to be another issue
L
leathernotch
41
  • Mar 13, 2007
Going to move post to checklist
HISSIN50
34
129
Mar 13, 2007
  • Mar 13, 2007
I'd keep vac leak hunting, based not only on symptoms but also on the vac reading.
You really don't know that the car idles correctly when cold because you dont have a good warm idle to compare to. The cold idle goes through several steps of RPM.
I'm sure you'll find the answer in the surging idle sticky.
Good luck.
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
C
Engine Cylinder 5,,7, & 8 run significantly cooler than the other cylinders
  • Crisfixes
  • Sep 27, 2025
Fox 5.0 Mustang Tech Sep 27, 2025
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
