pounds per horsepower?
AC91GT
36
Belmont, NC
So I took my 91 vert across the truck scales @ work. WIth me in it (200lbs) the damn thing weighed 3740 lbs. My questions is, with 3.55:1 gears, how much horsepower to make this thing fast? Or at least feel fast and not like a turd. Stock motor, Art Carr auto and MM suspension. I am think I want 10 lbs/hp or less. What does everyone else think? Thanks.
As you add HP to this car the wieght is going to drop. Such as the addition of aluminum heads which will help with some wieght savings. Also look at putting some parts into your car that reduce the wieght and you could hit your target of 10lbs per hp easily.
Yeah, I believe my old 99 ranger weighed in the 3,200lb range.
4,500 lbs is the gross vehicle weight rating (GVWR), in which what the car's suspension can safely handle, or something to that effect.
Sorry been away all weekend. Car may be heavier due to subframes and other suspension components. Definitley looking to add aluminum heads but also want a power adder, KB or Turbo. Cost is the hold-up right now. I am thinking I will spend about 5k to finish. Torque will overcome weight if it is high enough. Horsepower is just a by product. Thanks for the responses.
