a friend of mine took my heads and installed bigger valves and did a valve job and better springs etc. got them back and poured some lacquer thinner in the ports and pretty much all of the valves seep a little bit, it doesnt just come out instantly. you have to let it sit for a sec and then it will finally trickle out a bit around the valve, it doesnt pour out but it just a little wet under the valve, nothing major.
is this normal at all?? or should it be sealing 100%
if not then i will give them back to him to fix them.
