I know this is a place not to be cheap on, but I was wondering if anybody has seen or had any experience with something like this? Power Brake booster conversion I want a little more stopping power until I can afford to do a front disk conversion. I like that I won't need to drill the pedal support and install a different pedal. Also the way I figure I should be able to get a disk/disk master cylinder and bolt to the booster when the time comes for the disk swap. Dose it seem like something I should keep my eye out for? I can't see spending over $100.00 at one of the mail order shops just for a name brand, but again I know this isn't the spot to be cheap on.
So I figure if I am going to be redoing/replacing the the braking system at this time (Also installing a line lock.) It would be the time to do the booster install.
