I would suggest running 24lb injectors. This is assuming the power output will be about 300hp. If you have plans of boost in the immediate future then 30lb may be more appropriate, maybe bigger depending on boost levels.
I did use an excel calculator that I wrote to come up with this (I am not just making up numbers). If you would like to see it post your email or pm me, this site is not friendly to tables and it is a real pain to format it into Word. If you are not familiar with excel though it may just be confusing.
The fuel pressure should be fairly close to 40psi. I would set it to 39psi and try to tune from there. You just have to get close enough to correct so that the computer can adjust fuel ratio with injector duration.
The Ford systems seem to be about 39psi, other makes might go 50-60, but not many Mustangs should need that much pressure. Maybe very high compression or boost?
Come back if you still have questions
Good Luck
jason
