POWER DISC!!
  • Thread starter Thread starter ShAkE N BaKe!!
  • Start date Start date Aug 9, 2007
ShAkE N BaKe!!
144
  • Aug 9, 2007
I'm going to get the Granada Disc Brake setup from www.discbrakeswap.com.
- I heard that with manual disc, you still have to press the brakes really hard to get the car to stop.
- If I get the Granada Power Disc, will this it a lot easier to stop?
*How hard is it to install power brakes into a '65 coupe?*
BlwnGazkit
153
Richmond, VA
Aug 9, 2007
  • Aug 9, 2007
With a properly sized Master Cylinder (MC) manual brakes aren't terribly difficult to use. They do require more pressure than power brakes.
That said, disc brakes actually take more power to stop than drum brakes do to the physics of their design. However, disc brakes are much nicer to use and in my opinion make the car more driveable since the brakes are more predictable. Drum brakes have a tendancy to grab at different times and can cause the car to jerk to one direction. Disc brakes grab together unless there's a problem with them.
I'm not sure but you can check with UltraStang and his website, www.UltraStang.com, and see if the Fox Brake boosters will bolt in. If so then it's pretty simple and I think he had a write-up of an install.
jadesville
the polarbear conservation corps protects a polarb
20+ Year Stangneter
Oct 8, 2003
2,189
Gresham, OR
Aug 9, 2007
  • Aug 9, 2007
I have no problem stopping my car, it really depends how much weight you got up front and distribution. I daily drove my car through traffic and had no problems at all stopping. It's up to your level of comfort though.
ShAkE N BaKe!!
144
  • Aug 9, 2007
has anyone ever bought the Granada power brakes?
enferno
418
  • Aug 10, 2007
it's really easy to install a power brake booster. it pretty much just bolts on to the firewall with 4 or 5 bolts, then you bolt the MC up to it with 2. it's an easy and effective swap. some kits even come with new pedals and pushrods, etc.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 10, 2007
  • Aug 10, 2007
I've heard of a few people on here who bough from discbrakeswap.com. I think thats Degin's site if I remember. I've never heard anything bad about his stuff. Everyone who has purchased stuff from him has said that it is good quality and very complete.
E
EricButler
9
  • Aug 10, 2007
Put this setup on your car and you will not believe how the brake work. This system is light years ahead of the vacuum assisted brakes and you don't have to worry about low vacuum when you have a radical cam. It is worth every penny for this system. I have it on my car and it is unbelievable.
http://www.hydratechbraking.com/
BlwnGazkit
153
Richmond, VA
Aug 10, 2007
  • Aug 10, 2007
That's the same as a HydroBoost setup from a newer mustang. You can pick one of those up ina junk yard and run them off a power steering pump.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 10, 2007
  • Aug 10, 2007
Yep, the only thing that the kit gives you that a junkyard wont is the spiffy mount plate and the pedal adaptor. And of course the steel braided lines. Neither of those are that hard to fab. Even with my modest experience in fabrication I'm sure I could do it. And any custom line shop can build you what you need or you can have one end re-flared of a stock line for a versalle.... how ever the hell its spelled.
F
frost0100
127
Wilmington, NC
Aug 10, 2007
#10
  • Aug 10, 2007
  • #10
I bought the kit from diskbrakeswap - and was really pleased. I too went with the manual disc brakes. Everything went together real easy - but car hasn't run yet, so I can't talk to you about how they feel - but I did a lot of research before deciding to go manual disc.
ShAkE N BaKe!!
144
#11
  • Aug 10, 2007
  • #11
why did you decide to go with manual vs. power on you Granada swap?
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
