Power loss above 3K
TrueBlue95GT
966
Connecticut
It's an 88 GT with a MAF conversion and some small other things. Also, New O2 sensors and a new ECT sensor. When the car warms up, there is no power above 3K RPMs. I can turn the car off and start it back up and it takes like 2 min to get back to the same problem. It sounds like something related with the change from open loop to closed loop. Help!!!!
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Wal-Mart may now have the LCD display scanner for less than $35
Don't find any codes? then replace the TFI. TFI problem symptoms are a loss of power at higher RPM's when the engne is warm.
Alright...checked the codes and only came up with codes like EGR and Smog stuff, which was removed...Still the same problems...replaced the TFI module...to no avail. It runs the same. This is really weird. I rode in it today and it almost feels like when the car switches to closed loop, it pulls a bunch of timing above 3800rpms and then the rpms keep on dropping. It also stalls when it comes to a stop. Here are the things I noticed...it has an exhaust leak where the headers meet the h-pipe, since we removed the heat, we plugged the ECT sensor straight into the manifold with an adapter, and there is a metallic ticking noise that happens at all rpms. The ticking noise is probably a lifter that didn't saturate with oil....Please give any advise applicable.
Post the all the codes you got. Depending on what you got, you may have a limp mode condition. Some of the EGR fault codes point to other problems
