Power Loss During Acceleratiom
0h1saleen
Hello everyone, I recently bought a 2001 Saleen sc281 and am having an issue. The issue I am having is that after the car is driven for awhile it will start to randomly lose power (feels like a hard miss, tachs fluctuate, amd seems like car is losing actual power as even the ac blows warm then goes back toncold) during acceleration. It seems to happen the most in 2nd and 3rd,or as you give it more gas from cruising, as you are accelerating then it kicks itself back and is normal again. The only thing I had done to the vehicle prior was remove the Mach 460 amps, upgrade the factory stereo and replace the ac compressor. May be a coincidence but it didn't seem to start doing this until I had the compressor replaces but that may just be coincidence. Any help would be GREATLY appreciated
  • Sponsors(?)
wmburns
SN Certified Technician
Aug 14, 2009
5,849
507
204
Houston Texas
Here is a recent thread that IMO may have a similar root cause.
theft light flashing no start sometimes
That is don't ignore the role that a charging system problem might play in this.
Shuttleman83
108
9
28
USA
If A/C is getting warm, check compressor and connections to it - also, coils and charging power. Maybe A/C WOT relay in CCRM if it has one?
232937
20
palm springs ca
I just changed the ccrm and it was fine for a whole day I thought I was all good then about an hour ago it did it AGAIN. I'M SO OVER IT. why me!
Shuttleman83
108
9
28
USA
Do the dummy stuff first. Coil Voltages, clean fuel and or fuel filter replaced, fuel pressure, etc. Also proper charging with battery / alt at load.
Another thing to try is open trunk, smack intertia switch so red button pops up, then push it back down to reset it.
wmburns
Aug 14, 2009
5,849
507
204
Houston Texas
If a CCRM problem is suspected this will show up as a power interruption to the power at fuse F2.2 and F2.8. How to test for power in fuse F2.2 is mentioned in the other thread. But basically using an "add of fuse" or "add a circuit" to create a way to monitor power while driving. I recommend using a test light that way it's easily seen while driving. IF the test light blinks during driving this confirms the theory.
A bad or loose CCRM / PCM ground can also "cause" the CCRM to drop out. That's why it's important to double/triple check the grounds around the radiator core support on BOTH sides.
1999-2004 MY fuse panel schedule:
Reactions: Shuttleman83
232937
20
palm springs ca
I have that switch bypassed
wmburns
Aug 14, 2009
5,849
507
204
Houston Texas
FWIIW, I don't see any way that a problem with the trunk IFS switch could "cause" these specific symptoms. A problem with the IFS switch would affect the FPDM and the Fuel pump itself. The IFS switch isn't going to affect over all power to the car or the power to the CCRM.
The exception to this is for the Cobra. The Cobra cuts in the IFS in the fuel pump pilot duty circuit and therefore might could cause the fuel pump part of the CCRM to "bounce".
Shuttleman83
108
9
28
USA
Maybe but I've heard some guys complain that art WOT pulls the inertia will give out or cause intermittent issues. Worth a try I guess but you are probably right.
232937
20
palm springs ca
It's not unplugged I just simply cut the pink wire and connected it directly .. Hey Mr burns. So I replaced the ccrm with one from the pick a part and it worked fine all day ..much longer than normal time intervals but then towards end if day it did it again. ????
