Power output for my Stang
Greetings to all. I USED to be a member. I had given up all hope of the Mustang cummunity, and had moved on... or so I thought!
Well, I am back in greener pastures, and have since picked up another Mustang. Number 3 to be exact. This one I bought already modified, and have done some work to get it in better condition then recieved.
My question is, what should my power output be with my setup? Here goes the list of mods. Bare with me. Thanks. =)
306 @ 8.5:1 ratio (due to the turbo setup that is sitting in my garage, waiting install)( it is a Garrett 61mm/ 96mm .60 A/R
afr 165 heads
track heat intake with phenolic spacer
f303 cam
1.6 rrs
cometic mls gaskets
msd 6al
70mm tb
bbk headers
hpipe
timing is set at 13-17 degrees bdc usually.
If anyone can recommend changes/ upgrades to make better power W/O going big buck route, I would appreciate it.
Thank you again. And im glad I made the right choice coming back!
