Power Rack Leaking
Ok folks I've got a question, I'm hoping someone can help out. My steering rack is leaking on my 92 5.0 GT. The hard line that runs from the steering box to the front of the rack is leaking. Has anyone ever seen this line leak? It's leaking at the steering box. Short of pulling the rack out I couldn't see real good what is in the way. Especially with the fluid all over the place. Is there a diaphram right at the box, that could be leaking? Has anyone else had a leak in that spot?
Most likely what punisher said..the o ring under the fitting may have gone bad but I did change a friends a little while back where the line had a small hole in the bend before the rack..clean it and check it out..not that hard to do..rack comes down real eask from under neath car as well...
