  • SN95 4.6L Mustang Tech
Power shifting
  • Thread starter Thread starter mustang70
  • Start date Start date Apr 18, 2005
mustang70
2,445
San Diego
Apr 18, 2005
  • Apr 18, 2005
How many of you have to granny shift from 1st to 2nd? I've noticed when I power shift my back tires spin enough to make the rear end sway a little. I'm shifting at 5k since I've read anything higher is pointless. Should I wind it out a little more to stop the spin or just save up for tires? I can only imagine what it would be like with gears.
Mirrahasmycar
210
CT
Apr 18, 2005
  • Apr 18, 2005
just try and control it, wait untill you need to change your tires to upgrade, unless you are taking it to the strip often
bbueschel
26
Maitland, FL
Apr 18, 2005
  • Apr 18, 2005
When I had my 245 kumhos and a couple bolt ons(no gears, I would nuke them like crazy in first, 80-90% in second and chirp third hard. Went to 315's Dr and no spin at all in first. Next I got my novi 2k on there with longtubes and 4.10's and traction problems have resurfaced.
Y
Y2K_MustangVert
185
  • Apr 18, 2005
This might sound stupid, but how do you guys catch third? First gear it's hard to not spin, and I will catch second occasionally, but third....no way. Is there a trick to your method of shifting or what is the deal? Sorry, didn't mean to hi-jack the thread.
damacman
529
Phoenix, AZ
Apr 18, 2005
  • Apr 18, 2005
with stock tires, it's fairly easy to chirp fourth . . .
mustang70
2,445
San Diego
Apr 18, 2005
  • Apr 18, 2005
I don't get any sound going into third. The car just lurches forward when I let out the clutch. It's not near as bad as it was before the control arms though.
G
ghoststripes
California
Apr 19, 2005
  • Apr 19, 2005
ya get wheelspin from 1st to second (shifting at 5500 RPM), and i chirp then in third. this isn't the best way to shift, cause you'll lose some time in the 1/4. any suggestions to eliminate this?
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
