Power steering and wheel slop
68converted
772
Colorado
Never mind. I searched the wrong way. I got it covered now.
I searched the treads... no luck. I have a solid foundation, new GT front, KYB's, 620 drop coils, new upper and lower arms, and 1-1/8" sway bar. Ball joints are in great shape and no slack in the joints. I need to deal with the slop in the steering but how. I have about 3-4" of rotation either side before the PS kicks in. I know/think that it is the steering box, but what do I do about it?
There is threaded flat top screw/bolt on the top that is out about 3/4". Is this what I turn to tighten it up? I cannot find a reference out there aside from replacing, (not an option just now) and my big green book is MIA. Help
What you discribed is the sector shaft adjustment within the steering box. If it's only 3/4" out from the jamb nut, it's already been adjusted in quite a bit. This would indeed be indicative of a worn steering gearbox.
How is the pitman arm on the power steeing control valve?
Usually there is quite a bit of play at this connection in the factory power steering systems. The ball socket within the control valve can be adjusted to a certain degree, and most of the slop taken out if required.
sounds like your gearbox is the problem, but i was gonna ask about your power steering control valve. There is a ball joint on it and they do wear out. Not sure if you had already replaced the valve, so i thought i would mention it.
