Power steering leaks
chucks1967
54
Im getting very frustrated with this power steering issue... I have replaced the control valve, got all the hose leaks fixed, but now im leaking out of the stud area. Is there any thing I can tighten that will stop this leak? This is my last leak area! Thanks for the help in advance.
Hmmm… You're getting ATF out of the ball stud? That's a failure of the main spool valve seal in the valve assembly. Call the people who supplied you with the valve, it's junk and they need to replace it. Do you have the steel fluid lines properly clamped to the valve body? If so, you'll need a replacement clamp, too, which they should also provide.
