  • 1994 - 1995 Specific Tech
power steering pump install
  • Thread starter Thread starter BlackVert
  • Start date Start date Jun 8, 2004
BlackVert
5,589
9
98
Bethesda, MD
Jun 8, 2004
  • Jun 8, 2004
my power steering pump is going so i bought one today at advance auto. $99 but i get $45 back when i return the old one. is that an ok deal?
anyway, i want to do it myself ... it looks pretty easy. think i can do it in an hour?
also, what should i watch out for?
BlackVert
5,589
9
98
Bethesda, MD
Jun 10, 2004
  • Jun 10, 2004
i have heard this is a common problem. anyone?
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Jun 10, 2004
  • Jun 10, 2004
Which brand did you get? You obviously bought a reman unit since there is a core charge. These units usually have a lifetime warranty so for the money it is a good deal. Hardest part is getting the damn pulley off the pump. Mine doesn't like to come off.
R
RUSTY R
10
Jackson , MISSISSIPPI
Jun 10, 2004
  • Jun 10, 2004
not bad price but you have to have a special puller to get the pulley off. to put it back on just use a long bolt with a nut and washer to press it back on.
good luck
4dStang
Banned
Oct 23, 2002
718
Near St Louis, Missouri
Jun 10, 2004
  • Jun 10, 2004
I changed mine twice with remans before buying a used OEM. The oem actually worked. The very first one I bought was an autozone one and the lower nipple did not fit my 95 so I was forced to pay $50 more and go somewhere else to get the right pump.
The pulley removal/installation is easy if you have the $30 tool. I just ended up buying it and adding it to my tool box because I work on 5.0's so much. Remember, NEVER try to pry the pulley off. It will not come off that way. Use the special puller available at autozone or most parts stores. It usually takes some elbow grease to get it off, but eventually it will pop off. Oh, leave the belt on for the first half too when removing it, makes it so the pulley doesnt spin. The bolts behind the pulley are reverse torx. I believe they are a 35 or 40 torx. I will look later when I get home. Buy that tool too from the parts store. DONT use any thing else. You will just FUCG up the bolt. I have had to file and grind too many peoples fug ups because of that problem to get that pump out. What a loss of time. Other than that, it is a piece of cake. Undo a couple of hoses and lift the bad boy out. Put the new one in and reverse the removal for installation. Fill with ATF.
Can you tell I have done this a few times?
PM me for more info. If needed.
CB
BlackVert
5,589
9
98
Bethesda, MD
Jun 10, 2004
  • Jun 10, 2004
thanks for the info. maybe i'll get to it this weekend ...
saxman9801
241
Boise Idaho
Jun 10, 2004
  • Jun 10, 2004
When changing the power steering pump do you have to bleed the system when done? I just need to change my fluid it is kinda nasty looking in there, any help? Dan
BlackVert
5,589
9
98
Bethesda, MD
Jun 11, 2004
  • Jun 11, 2004
not sure but it says oem reman on the box. i guess it is a ford reman.
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
D
Power steering pump bracket with A/C
  • Dczookster
  • Apr 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2025
rednotch
