Power Steering Pump Leak
The tie rods are not disconnected or adjusted when you lower the rack to change the power steering lines. Since you are not tightening or loosening the tie rods, or permanently repositioning the steering rack, the toe in/out alignment will not change when the rack is bolted back in place.
ok once i get under there and inspect things i will see if i can see what on the rack needs to be unbolted to make it easier
