GroverDill said:Standard rotation water pump
March Alt bracket PN#1465
looked like this before the blower.
When you loosen the alternator, you take the top bolt out, then you loosen the bottom bolt and move the alternator over to the right to put the belt on, then pry the alternator back to it's mounting point and put the bolt back in.stang22 said:If you run the belt on top of the tensioner, how does it make the belt tight? Do you turn the tensioner upside down?
Tim
It's all good Tim.stang22 said:EDIT: I think I know what you are saying. Sorry bro!![]()
The march alternater bracket you mentioned pn.1465 does it completely eliminate the stock bracket?stang22 said:I guess I just can't visualize it, not to say you are not right by any means. Here is groverdill's old setup. There was no smog pump, but you get the idea.
Well actually you have the correct water pump pulley if you have the Ford Racing pulley setup.aod92 said:Thanks guys this helps a little. And yes i don't have a/c or a smog pump. My only problem is i have the ford racing underdrive pullys on my water pump and crank. So what size pulley do i need to step up to on the water pump. And does'nt this kind of defeat the purpose of the underdrive pulleys. When i'm only trying to make more power by eliminating the power steering.
