  • SN95 4.6L Mustang Tech
power steering pump
  • Thread starter Thread starter spederman
  • Start date Start date Aug 10, 2007
spederman
732
  • Aug 10, 2007
I think my PS pump is going out. I found two golf ball sized oil spots on the garage floor with really black looking oil. I just changed the engine oil last week so that is still really clean and isnt black. I just got an 8 rib belt conversion and right after the install, Ive had this really high pitched whine with a moaning sound. I wonder if the conversion with the new pulley somehow killed the stock PS pump. It has 30K miles on it. Do they make any performance PS pumps that are better than stock?
V
varad
26
Philadelphia
Aug 11, 2007
  • Aug 11, 2007
i changed mine with a stock one and it still whines. I think one site makes better ones I just can't remember it.
screamin gt
5 Year Member
Apr 9, 2007
393
central CT
Aug 11, 2007
  • Aug 11, 2007
I would search out the leak before buying replacement parts
btw if it is you psp then dont bother putting that 4th pita bolt back in its worthless and shouldnt be there in the first place.
TweekedGT
1,274
Alberta
Aug 11, 2007
  • Aug 11, 2007
Sounds like the pump is toast and is leaking out the front seal. Just get under there and see if there is fluid. Mine just blew a week ago and I had fluid all through my engine bay, fluid was falling on the belt and was getting thrown all over.
spederman
732
  • Aug 11, 2007
I was just under my car for looking for any wet spots or drips. Its dry as a bone. I have no idea what the hell those spots are from on the floor. But i still have the groan. I'm not sure if the groan is something that comes with going with an 8 rib setup, dont see why it would.
I tried to pinpoint the location of the groan, which is kinda hard, but seems to be coming from the alternator area, maybe lower, but around that area. I'm confused The fluid level is fine, when its cold, its barely below the max line and once i start it, the level seems to come up to the max line.
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
A
Engine 99 V6 Steering Pump Replacement
  • abs68206
  • May 23, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2025
abs68206
A
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
