power steering - Rack is moving
subcreep
30
Jax, FL
Okay, I just replaced a worn out rack on my '92 LX and the new rack is moving side-to-side when I turn the wheels. The new rack is the quick ratio, and I installed it with prothane poky rack bushings. I took the car to get it aligned yesterday and they told me the rack was moving, and they said that they had tried to tighten it down while it was on the lift. What are the torque specs for the rack, and is there a difference in diameter for the bushings on the quick ratio rack versus the normal rack? I really don't want to pull this rack back off after all of the work it took to replace it!
The rack and mounting bushing diameter should be the same for any of the racks. The rack mount bolts are good sized, and do take a good bit of tightening. Cant quote the spec right now.
It is also possible that if the poly bushings were not tight, they are allowing movement. If you have the offset bushings and they are not tight, they may have more tendency to rotate.
Tightening should fix it.
Energy Suspension sells three different Rack & Pinion bushing, all dependent on the year on the rack. Since you replaced it, there is no telling what year rack it is, as I think all will work.
Back to the real problem, yes, there are different O.D. bushing for the rack & pinion bushings, you got the wrong ones for your rack.
My lx is a '92, the bushings I bought were for a 90-93. We only torqued the bolts down with the impact wrench. I think the thing puts down 120 ft-lbs of torque. Anybody know the torques specs?
