if i remove my power steering pump completely....do i need to do anything to bleed the system, or is it a self bleeding system??
How do i drain out the rack and pinion of the fluid??
How much fluid does it take to fill the whole system up??
Thanx
Thanx
Why are you taking off the p/s pump. Are you deleting it? What? If so you should go to a manual rack. The turn ratio is different for a power rack as compared to a manual. The p/s system holds between 2-3 pints.
