power steering ?
  • Thread starter Thread starter manny
  • Start date Start date Jun 8, 2006
M
manny
590
TAMPA FL
Jun 8, 2006
  • Jun 8, 2006
has any one out there taken out the power steering gear and replace it with the manual type? i will be running a 70's series tires up front and yes the car has a v8. thanks in advance.
98CobraClone
592
Ripley, Ohio
Jun 9, 2006
  • Jun 9, 2006
I removed my old power steering rack and replaced it with a flaming river manual rack, if that's what you're asking
Wart
I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
408
NE Ohio
Jun 9, 2006
  • Jun 9, 2006
Yes.
The manual rack has a much better feel.
If you have a tendency to turn the wheel while the cars sitting still you'll get over it real quick.
Mstng2
789
- - Zion - -
Jun 9, 2006
  • Jun 9, 2006
Yep, Many of us have, because we are Manly Men! We have a desire to strenghten our arms by yanking on a 13' steering wheel to turn the tires 1 inch. hah ahhah Really though all you do is swap out to a manual rack. The knuckle is slightly different and you do need a manual knuckle. Other than that it's pretty much a straight swap and nets you less maintenance and 1-2 tenths in the 1/4 mile.
JonDawg
Mstng2 supplied me with my pair
422
See those taillights right in front of you?
Jun 9, 2006
  • Jun 9, 2006
I have 60 series low pros on the front of mine, with the manual R/P. Even after I put on the smaller steering wheel, its not too much effort to turn the wheels. I still dont recommend it while the car is sitting still, but its not the worst thing Ive ever had. Now a 2-ton Dodge truck is a beeoch with the manual steering.
Dano78
2,633
Vancouver, WA
Jun 9, 2006
  • Jun 9, 2006
I've got 195/60/14s on the front, V8 Auto with a manual rack. It's not too shabbly.
As long as you don't put a mini-spool (like I did) or a tough locker unit in the rear axle, you'll won't notice too much difference.
M
manny
590
TAMPA FL
Jun 10, 2006
  • Jun 10, 2006
thanks guys. guess i'll go look for a manual knuckle also.
J
Johan
81
Waldheim, LA
Jun 10, 2006
  • Jun 10, 2006
I'm in the minority here, I much prefer a power rack. That may not make me as manly, but I much prefer the quicker steering of the power rack - 3 turns lock-to-lock vs 4 turns lock-to-lock.
9
90lx
91
  • Jun 11, 2006
I drove my car for years with the power steering belt off cause the pump was really noisy. It wasn' the correct brackets and pump for the car. I had 205/60's on it. Parking lots were some work, but other than that it was fine.
I
IMACHU2
28
#10
  • Jun 12, 2006
  • #10
I ditched the power rack for the manual rack. The problem is the stock II manual rack is way too slow!! The lock to lock is like 4 1/2 turns! (guess-ta-ment). I am going to put in either a flamming river rack or a stock power steering rack without a pump back in. I think sleeper put a II power rack in his car with no pump. He just used a P/S jug from some newer car from the wreckers. (many new cars have a jug with two spiggots). The manual rack is safe and works fine, just not very sporty. Also I know the tie rods are different and possibly the rag joint. (I transformed my car 10 something years ago, so the details are getting fuzzy) The steering effort is not too hard even with the 302. My Lada Niva takes more effort
jeffnoel
1,638
Clovis, CA
Jun 12, 2006
#11
  • Jun 12, 2006
  • #11
It's not a question of manliness, the problem is Ford PS are noisy even when new. The manual rack is also smaller diameter than the power version which gives more room when using a non-II oil pan (like my 7-qt deep sump).
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Drivetrain 1987 Mustang notch drive questions
  • Shannonfox123
  • Apr 12, 2026
Fox 5.0 Mustang Tech Apr 12, 2026
AeroCoupe
