Power Window Motor?
jaybertx
387
Sarasota, FL
My drivers side power window quit working. It's been down for a few months and I finally decided to try to fix it. I tried tapping the motor with a hammer under load to no avail. I pulled the motor out and hooked it back to the switch. I hit it and the motor ran. I reinstalled it in the door and the window worked. I put the door back together and the window still worked. I then turned the engine on and tried it, again it worked. I rolled down the passenger side window and back up. Then I tried the drivers side and it won't budge.
Before I go pulling the door apart again *grumble* are there any other possibilities at this point OTHER than the motor? I don't want to go spending $100 on the motor and have that not be the problem.
When the window did work for a few minutes, the tracks seemed to move smoothly and without any noticeable "struggle". When I push the button, I here a loud click (relay?) but the motor doesn't even try move.
Any help or ideas would be much appreciated.
Thanks!
My 2002 GT had the same problem. One day all of the sudden my driver's side windows wouldn't roll back up. When I hit the button I could hear an audible click, and if I held it down I could see my dome light dim, but nothing would happen. My car was still under warranty and ford installed a new window motor, fixing the problem.
