power window problem
hoamskilet
90
Belvidere, IL
I've got a 95 cobra with the drivers side window stuck down. As of right now, when I push the up button, I think I can hear a click inside the door. If I push the down button I can hear a little click in the relay that's in the bottom left of the door panel. Anyone have any suggestions as what could be wrong? I just wanna cover all grounds before I go replacing a motor or somethin. Thanks.
im not too sure about how the SN's are wired. have you pulled the door panel and checked for juice at the motor wire connector when the switch is pushed? that would help diagnose it.
if the motor is shorting out, it could be popping a CB (if it has one)....my best guess. good luck and bump.
if the relay is clicking its still good... my car did the exact same thing and as soon as i replaced the power window motor it fixed it.... it works better now then ever...i got mine from the junkyard for 50 dollers....brian
